Import Design Study Geometry from Onshape/STL
- Start a SimSolid session.
Import geometry from Onshape or STL:
Import from... Process Onshape - On the main window toolbar, click
(Import from cloud) to access
models from Onshape. - Browse for the desired file and click Open.
STL - On the main window toolbar, click
(Import from file). - Browse for the desired file and click Open.
Each import is placed in a new Design Study branch of the Project Tree.Note: You can easily mix and match between different CAD sources. One SimSolid project can have CAD data from Onshape, SolidWorks, or any other supported CAD format. - On the main window toolbar, click
