- Linear Structural Analysis
Analysis that assumes the model is loaded slowly (static) and stresses do not exceed the yield strength of any part material (linear).
- Non-linear Structural Analysis
Three types of non-linear analysis are currently available: non-linear separating contact, geometric non-linear, and material non-linear.
- Buckling Linear
You can create and solve linear buckling problems in structural analysis.
- Multi-loadcases
You can use Multi-loadcases to run multiple linear structural analyses with common constraints. Linear structural analysis assumes the model is loaded slowly (static) and stresses do not exceed the yield strength of any part material (linear).
- Sequential
Sequential analysis is any type of structural analysis performed on a structure under prior loading (also termed preloading or prestressing).
- Structural Thermal
Structural analysis linked to steady state, transient thermal, thermal imported, or temperature load can be created using the Structural Thermal Workbench.
- Structural Superelement Export
Used to export the super elements as a DMIG file. This file will include stiffness matrix and the load matrix, if there are loads and boundary conditions applied to the model which is solved for condensation.
