Create Buckling Responses
Create buckling load factor responses for the entire model.
  1. From the Design Explorer ribbon, select the Responses tool.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
  2. Use the dropdown menu on the left side of the guide bar to select Buckling.
  3. On the guide bar, click to create the response.
  4. Optional: Make any desired modifications to the created response in the microdialog.
