2026
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Goals comprise objectives and constraints.
Discover new features and enhancements in Inspire.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Create implicit models with primitives, lattices, point clouds, fields, offsetting, Booleans, inverting, smoothing, morphing, and filleting.
Set up your model and run a structural analysis or optimization.
Inspire Motion provides Multibody Simulation (MBS) capabilities to analyze the motion, dynamics, and interactions of interconnected rigid or flexible bodies within a system.
Prepare and run a computational fluid dynamics simulation.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses. Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses.
An output response is a measurement of system performances, such as mass, volume, displacement, or stress.
Objectives are metrics to be minimized or maximized in an optimization exploration. Common examples are minimizing displacement to find the stiffest design for a system or minimizing mass to find a lightweight design.
Constraints can be added to an optimization and need to be satisfied for a feasible exploration.
Use the Evaluate tools to run the exploration and review reports.
Set up and run a basic porosity or thinning analysis.
Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
Adjust the materials and environment of objects in the scene to create a photorealistic image.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
