Jump to main content
Radioss
Radioss
2026
Index
  1. Home
  2. Radioss Reference Guide
  3. Engine Input
  4. Initial State
    Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
  5. /STATE/SHELL
    In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for shell element in state file (STA-File).
  6. /STATE/SHELL/ORTHL
    Engine Keyword Describes the orthotropy direction for shell.
  • Welcome
  • What's New
    View new features for Radioss 2026.
  • Radioss Overview
    Radioss is a leading explicit finite element solver for crash and impact simulation.
  • Tutorials
  • Radioss User Guide
  • Radioss Reference Guide
    • File Extensions and Formats
      Current Radioss format uses the 12x extension format.
    • Single File Input
    • New Keywords in 2026
    • Starter Input
    • Engine Input
      • Engine Keywords Syntax
      • General Controls
        Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
      • Deletion/Input Modifications
        Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
      • Animation and Post-processing Output Files
        Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
      • Implicit Solution
        Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
      • Kinematics and Loading
        Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
      • Time Step
        Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
      • Initial State
        • /DYNAIN/DT
          Engine Keyword Define time output frequency and parts to be written to the state file.
        • /DYNAIN/SHELL/STRAIN/FULL
          Engine Keyword Describes the strain state for shell in LS-DYNA format.
        • /DYNAIN/SHELL/STRESS/FULL
          Engine Keyword Describes the stress state for shell in LS-DYNA format.
        • /STATE/BEAM/AUX
          Engine Keyword Describes the internal variable state for beam.
        • /STATE/BEAM/FULL
        • /STATE/BRICK
          In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for solid element in state file (STA-File).
        • /STATE/DT
        • /STATE/INIMAP1D/Keyword3
          Engine Keyword A state file is written with mapping data as functions (/FUNCT) or generated into a binary file.
        • /STATE/INIMAP2D/Keyword3
        • /STATE/NO_DEL
          Engine Keyword Writes the state file for only non-deleted elements.
        • /STATE/NODE/BCS
          Engine Keyword Boundary conditions for Node. The boundary conditions applied to nodes be written to the state file.
        • /STATE/NODE/TEMP
          Engine Keyword Describes the temperature for nodes.
        • /STATE/NODE/VEL
          Engine Keyword The velocity of a node is written to the state file.
        • /STATE/SHELL
          • /STATE/SHELL/AUX/FULL
            Engine Keyword Describes the internal variable state for shell.
          • /STATE/SHELL/EPSP/FULL
            Engine Keyword Describes the Epsilon plastic state for shell.
          • /STATE/SHELL/FAIL
            Engine Keyword Describes the failure criteria state for shell.
          • /STATE/SHELL/ORTHL
          • /STATE/SHELL/STRAIN/FULL
            Engine Keyword Describes the strain state for shell.
          • /STATE/SHELL/STRAIN/GLOBFULL
          • /STATE/SHELL/STRESS/FULL
            Engine Keyword Describes the stress state for shell.
          • /STATE/SHELL/STRESS/GLOBFULL
          • /STATE/SHELL/THICK
            Engine Keyword Writes shell thickness values to the state file.
        • /STATE/SPHCEL/FULL
          Engine Keyword Describes the stress state for Smooth Particle Hydrodynamic (SPH).
        • /STATE/SPRING/FULL
          Engine Keyword Describes the internal variable state for spring elements.
        • /STATE/STR_FILE
          Engine Keyword When writing the state file, /INISHE, /INISH3 and /INIBRI will be written in a separate file which can be asked for being compressed (using GZIP) or not. The state file will then resume to the nodes coordinates and element connectivity.
        • /STATE/TRUSS/FULL
          Engine Keyword Describes the internal variable state for truss.
    • LS-DYNA Input
      This manual provides a list of LS-DYNA input files available in Radioss.
    • Multi-Domain
      This manual contains the description of the keywords for the Radioss Multi-Domain.
    • Obsolete Keywords
      Keywords that are still supported, but no longer maintained (*) are considered obsolete.
    • Other Files
    • Definition
  • Radioss Example Guide
  • Radioss Verification Problems
  • Radioss Frequently Asked Questions
  • Radioss Theory Manual
  • Radioss User Subroutines
/STATE/SHELL/ORTHL
/STATE/SHELL/ORTHL
  1. A block /INISHE/ORTH_LOC or /INISH3/ORTH_LOC or /INISHE/ORTH_LOC or /INISH3/ORTH_LOC is written into each state file, for each part declared into /STATE/DT.
On this page
  • Format
  • Comments
© 2025 Altair Engineering, Inc. All Rights Reserved.
