/STATE/INIMAP2D/Keyword3
Engine Keyword A state file is written with mapping data as functions (/FUNCT) or generated into a binary file.
Definition
| Keyword3 |
- Compatible with QUADS or TRIAS in 2D and BRICKS in 3D.
- Frequency output and related part can be defined with Engine keyword /STATE/DT.
- For each
submaterial, state functions are generated in a file with incremental name
starting from ROOT_INIMAP1D_0001.sta.
- for volume fraction
- for mass density
- for energy density
- for burn fraction
- for velocity function
This generated file needs to be included in the following Starter run: #include ROOT_INIMAP1D_0001.sta
For Keyword3= FILE, file is compressed using gzip format. Frequency output is defined with /STATE/DT. First file is named ROOT_2D_0001.inimap.gz.
- Generated data can
be used subsequently in a target model using /INIMAP2D/VP,
/INIMAP2D/VE or /INIMAP2D/FILE. In the
target model, a frame will have to be defined and must be consistent with
mapping data, as described below:
2D Original Model 3D Target Model
