/STATE/NODE/VEL
Engine Keyword The velocity of a node is written to the state file.
/STATE/NODE/VEL
  1. A block /INIVEL/NODE is written into each state file, for each part declared into /STATE/DT.
  2. The main node of the rigid body(ies) attached to the selected part(s) is automatically written in the state file. The node will be included in the /NODE and /INIVEL output of the state file.
