/STATE/SHELL/STRAIN/GLOBFULL
Engine Keyword Describes the strain state for shell.
- A block /INISHE/STRA_F_GLOB is written into each state file, for each part declared into /STATE/DT, including the full strain tensor of the shells belonging to it.
- A block /INISH3/STRA_F_GLOB is written into each state file, for each part declared into /STATE/DT, including the full strain tensor of the 3-node shells belonging to it.
- For QEPH shell elements (Ishell=24 in the shell property), this card must be defined in the first Engine file (<rootname>_0001.rad) to get output in the .dynain file, even if output is not needed until later Engine files.
