/INTER/TYPE18
Block Format Keyword This interface manages indirect coupling between ALE and Lagrange for FSI applications. A penalty method is used and requires stiffness and gap values.
Minimal input is possible with only 3 parameters: surf_ID, grbric_ID, and Vref
Only solid hexaedral elements are allowed on the /ALE/EULER side.
/INTER/TYPE18/inter_ID
inter_title
surf_ID grbric_ID Igap Idel Istf
Stfval Vref Gap Tstart Tstop
Definition
inter_ID Interface identifier.
(Integer, maximum 10 digits)
inter_title Interface title.
surf_ID Lagrangian surface identifier.
(Integer)
grbric_ID Eulerian or ALE brick elements group identifier. Used for 3D analysis.
(Integer)
Igap Gap formulation flag. 11
= 1
Variable gap
= 1000 (Default)
Constant gap
(Integer)
Idel Node and segment deletion flag.
= 0 (Default)
No deletion.
= 1
When all the elements (4-node shells, 3-node shells, solids) associated to one segment are deleted, the segment is removed from the Lagrangian side of the interface.
Additionally, non-connected nodes are removed from the Eulerian or ALE side of the interface.
= 2
When a 4-node shell, a 3-node shell or a solid element is deleted, the corresponding segment is removed from the Lagrangian side of the interface.
(Integer)
Istf Interface stiffness definition flag. 2
= 1 (Default)
Stiffness is a user constant and defined with Stfval.
= 2
Stiffness is automatically calculated from Vref which must be input. Then Stfval is an optional scale factor.
(Integer)
Stfval Interface stiffness value or stiffness scale factor. 2 3 4
If Istf=1
Interface stiffness value.
Default = 0.0
If Istf=2
Interface stiffness scale factor.
Default = 1.0
(Real)
[ N m ] or None
Vref Estimated reference velocity between ALE materials and Lagrangian surfaces (only use if Istf=2). 4
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Gap Interface gap. 5
= 0
A constant global gap is automatically calculated.
(Real)
[ m ]
Tstart Start time.
(Real)
[ s ]
Tstop Time for temporary deactivation.
(Real)
[ s ]
  1. Vref is the reference velocity and can be considered as the estimated relative velocity between ALE materials and Lagrangian surfaces. It is advised to use the maximum value expected during the simulation. For instance, for ditching applications, the initial impact velocity of the structure can be used. For IED or mine blast applications, the maximum material velocity in the shock wave impacting the structure can be used.
  2. If Istf=1, the recommended value of Stfval is:
    Stfval= ρ⋅ V ref 2 ⋅ S el Gap MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaiaads hacaWGMbGaamODaiaadggacaWGSbGaeyypa0ZaaSaaaeaacqaHbpGC cqGHflY1caWGwbWaaSbaaSqaaiaadkhacaWGLbGaamOzaaqabaGcda ahaaWcbeqaaiaaikdaaaGccqGHflY1caWGtbWaaSbaaSqaaiaadwga caWGSbaabeaaaOqaaiaadEeacaWGHbGaamiCaaaaaaa@4D4E@
    Where,
    ρ
    The (highest) fluid density.
    V r e f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvamaaBa aaleaacaWGYbGaamyzaiaadAgaaeqaaaaa@39C9@
    Reference velocity.
    S e l
    Average surface area of the Lagrangian elements.
  3. If Istf=2, the stiffness value of the interface is automatically calculated from Vref and a scale factor Stfval with:
    S t f = S t f v a l . ρ ⋅ V r e f 2 ⋅ S e l G a p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaiaads hacaWGMbGaeyypa0Jaam4uaiaadshacaWGMbGaamODaiaadggacaWG SbGaaiOlamaalaaabaGaeqyWdiNaeyyXICTaamOvamaaBaaaleaaca WGYbGaamyzaiaadAgaaeqaaOWaaWbaaSqabeaacaaIYaaaaOGaeyyX ICTaam4uamaaBaaaleaacaWGLbGaamiBaaqabaaakeaacaWGhbGaam yyaiaadchaaaaaaa@50BC@
  4. It is advised to carry out a sensitivity study of the model with the interface stiffness. For that purpose, with Istf=2, the stiffness scale factor can be used and set to different values in each simulation (for instance the value can be changed from 1 to 2, 4, 10 and 100).
  5. Gap is the interface gap, recommended value is 1.5 times of fluid element size ( 1.5   Δ x f l u i d MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGymaiaac6 cacaaI1aGaaGPaVlabfs5aejaadIhadaWgaaWcbaGaamOzaiaadYga caWG1bGaamyAaiaadsgaaeqaaaaa@40E9@ ) along the normal direction to contact. If gap is not defined, it is computed using:
    g a p = 3 2 d i a g max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaadg gacaWGWbGaeyypa0ZaaSaaaeaadaGcaaqaaiaaiodaaSqabaaakeaa caaIYaaaaiaadsgacaWGPbGaamyyaiaadEgadaWgaaWcbaGaciyBai aacggacaGG4baabeaaaaa@421A@
    Where, d i a g max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaadM gacaWGHbGaam4zamaaBaaaleaaciGGTbGaaiyyaiaacIhaaeqaaaaa @3C9F@ is the maximum diagonal of fluid element, which is exactly like 1.5 Δ x fluid MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGymaiaac6 cacaaI1aGaaGPaVlabfs5aejaadIhadaWgaaWcbaGaamOzaiaadYga caWG1bGaamyAaiaadsgaaeqaaaaa@40E9@ for a regular mesh.
  6. Prior to version 2020, the fluid Eulerian or ALE nodes were defined using a grnd_IDs in line 1 field 1. This input format is still supported for legacy models with LAW5, 6 or 51.
  7. The accuracy of the interface is increased, if the mesh size of the ALE side is decreased. Thus, to increase the accuracy of the interface, it is recommended you refine the ALE mesh in the contact zone, and at least in the global normal direction of the Lagrangian surfaces.
  8. To increase accuracy, several TYPE18 interfaces with different gap and stiffness values can be used for different contact zones (for instance, for cases where the mesh size and/or reference velocity are varying substantially).
  9. If element deletion in case of material failure has been activated for the Lagrangian parts, it is highly recommended to use Idel=1 or 2.
  10. In the case of SPMD parallelization, each Lagrangian segment defined by surf_ID must be associated with an element (with a property assigned to it which can be /PROP/VOID).
  11. When gap is variable, the Gap value is ignored. When gap is constant, the Gap value is optional since it can be automatically estimated.
