/INTER/TYPE1
Block Format Keyword ALE boundary nodes can be tied to Lagrangian surface to achieve an interaction between fluid and structure.
This way Lagrangian surface is acting as a sliding wall boundary condition. It is
compatible for both 2D and 3D analysis.Figure 1.
| /INTER/TYPE1/inter_ID | |||||||||
| inter_title | |||||||||
| surf_IDA | surf_IDL | ||||||||
Definition
| inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
| inter_title | Interface
title. (Character, maximum 100 characters) |
| surf_IDA | ALE surface
identifier. (Integer) |
| surf_IDL | Lagrangian surface
- This interface is not compatible when the Lagrangian surface is in a rigid body.
- The Lagrangian surface normals do not need to be oriented in a specific direction.
- A small gap (positive or negative) is acceptable between the surfaces.
cannot be immersed inside the fluid domain. It should always be a boundary
surface.
- The Lagrangian surface must be connected (no free edges).
Figure 3.
- The interface models a sliding condition imposed by the Lagrange
structure.
Figure 4.
