/IMPVEL/FGEO
Block Format Keyword Describes the final position of a set of N nodes. The final position is provided by a node number. The node may eventually move.
| /IMPVEL/FGEO/impvel_ID/unit_ID | |||||||||
| impvel_title | |||||||||
| fct_ID | part_ID | fct_IDL | sens_ID | ||||||
| Ascale | T0 | Tstart | FscaleL | Dmin | |||||
| node_ID1 | node_ID'1 | ||||||||
| etc | etc | ||||||||
| node_IDN | node_ID'N | ||||||||
Definition
| impvel_ID | Imposed velocity block
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| impvel_title | Final geometry block
title. (Character, maximum 100 characters) |
| fct_ID | Time function
identifier. (Integer) |
| part_ID | Spring part identifier. 5
(Integer) |
| fct_IDL | Load time function
| sens_ID | Sensor
| Ascale | Abscissa scale factor for
fct_ID. Default = 1.0 (Real) |
| T0 | Time duration. 3 (Real) |
| Tstart | Start
time. (Real) |
| FscaleL | Ordinate scale factor for
fct_IDL. Default = 1.0 (Real) |
| Dmin | Distance between
node_IDN and
node_ID'N,
which will be rigidly connected. (Real) |
| node_ID1 | Node
| node_ID'N | Node identifier giving the
final position of
node_IDN. (Integer) |
- A velocity is imposed to node_IDN in the direction of node_ID'N. The initial position of node_IDN and node_ID'N are provided in /NODE.
- fct_ID defines the time evolution of the imposed velocity.
- T0 is the duration used to compute a scale factor on the velocity of
node_IDN. With
being the initial distance between
node_IDN and
node_ID'N:
Where is the function of fct_IDT.
- Abscissa scale factor,
Ascale is used to transform the function of time,
as:
- Initial node position node_IDN and final node position node_ID'N can be defined as a spring (node_IDN, node_ID'N) with zero stiffness. The spring part_ID is optional and can be used to simplify the input since a pre-processor can easily generate springs between an initial position and a final one.
- fct_IDL defines the time evolution of an optional concentrated load applied on all destination nodes node_ID'N.
