2026
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Defines boundary conditions on node groups for translational and rotational motion.
Block Format Keyword Defines a cyclic boundary condition on a structure in a fixed cylindrical coordinate system.
Block Format Keyword Defines boundary conditions on node groups using Lagrange multipliers. This keyword is not available for SPMD computation.
Block Format Keyword Defines the sliding wall boundary condition with collocated scheme (FVM).
Block Format Keyword Defines imposed accelerations on a group of nodes.
Block Format Keyword Defines imposed displacements on a group of nodes.
Block Format Keyword Describes the final position of a set of N nodes, input by coordinates.
Block Format Keyword Defines imposed temperatures on a group of nodes.
Block Format Keyword Defines imposed velocities on a group of nodes.
Block Format Keyword Describes the final position of a set of N nodes. The final position is provided by a node number. The node may eventually move.
Block Format Keyword Defines imposed velocities on node groups using Lagrange multiplier method.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
