/IMPTEMP
Block Format Keyword Defines imposed temperatures on a group of nodes.
| /IMPTEMP/imptemp_ID/unit_ID | |||||||||
| imptemp_title | |||||||||
| fct_IDT | sens_ID | grnd_ID | |||||||
| Ascalex | FscaleY | Tstart | Tstop | ||||||
Definition
| imptemp_ID | Imposed temperature block
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| imptemp_title | Imposed temperature block
title. (Character, maximum 100 characters) |
| fct_IDT | Time function
identifier. (Integer) |
| sens_ID | Sensor identifier.
(Integer) |
| grnd_ID | Node group to which the
imposed temperature is applied. (Integer) |
| Ascalex | Abscissa (time) scale
factor for
fct_IDT. Default = 1.0 (Real) |
| Fscaley | Ordinate (temperature)
scale factor for
| Tstart | Start
time. (Real) |
| Tstop | Stop time. Default = 1030 (Real) |
- /IMPTEMP is not compatible with ALE applications (/ALE, /EULER). Imposed temperature will not be applied to ALE nodes or ALE elements.
