/GRPART/GRPART
Block Format Keyword Describes the part groups which are selected from other part groups.
/GRPART/GRPART/grpart_ID | |||||||||
grpart_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
grpart_ID | Part group
grpart_title | Part group
item_ID1, item_ID2,..., item_IDn | List of part group
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
