Finite Volume Method Airbag Modeling
In Radioss the standard method for airbag calculation is the Finite Volume Method (FVM).
The FVM models gas flow inside the airbag, including the interaction with internal airbag components which could include internal walls, baffles, and so on. The airbag cards, /MONVOL/FVMBAG1 and /MONVOL/FVMBAG2 are used to set up the FVM airbag. Uniform pressure airbags can be used for debugging purposes to check unfolding, contacts, and global consistency of gas dynamic parameters. /MONVOL/AIRBAG1 can be used to activate a uniform pressure airbag for debugging.
/MONVOL/FVMBAG1/46
FVMBAG1
#surf_IDex Hconv
666000001 0
# AscaleT AscaleP AscaleS AscaleA AscaleD
0 0 0 0 0
# mat_ID Pext T0 Iequi Ittf
666400002 1E-4 296 1 3
# Njet
1
#inject_ID sens_IDsurf_IDinj
666400002 666000500 666200211
#fct_IDvel Fscalevel
666000200 1
# Nvent Nporsurf
1 2
# surf_IDv Iform Avent Bvent vent_title
666000015 1 0 0
# Tstart Tstop dPdef dtPdef IdtPdef
0 1E30 0 0 0
# fct_IDt fct_IDP fct_IDA Fscalet FscaleP FscaleA
0 0 0 1 1 1
# fct_IDt' fct_IDP' fct_IDA' Fscalet' FscaleP' FscaleA'
0 0 0 1 1 1
#surf_IDps Iformps Iblockage surface_title
666000004 2 0
0 0 0 0 0
# fct_IDv Fscalev
666000004 1
666000003 2 0
0 0 0 0 0
# fct_IDv Fscalev
666000003 1
# frame_ID kmesh Tswitch
0 4 20
# L1 L2 L3
0 0 0
# Nb1 Nb2 Nb3 grbric_ID surf_IDin Iref
0 0 0 0 0 0
# Igmerg Cgmerg Cnmerg Ptole
0 1e-04 1E-4 0
# qa qb Hmin delta_Tsca delta_Tmin
0 0 0 0 0
# Ilvout Nlayer Nfacmax Nppmax Ifvani
1 0 0 0 0
/MONVOL/FVMBAG2/46
FVMBAG2
#surf_IDex surf_IDin Hconv
666000001 0
# mat_ID Pext T0 Ittf
666400002 1e-04 296 3
# Njet
1
# Nvent Nporsurf
1 2
666000015 1 0 0
0 1E30 0 0 0
0 0 0 1 1 1
0 0 0 1 1 1
666000004 2 0
0 0 0 0 0
# fct_IDv Fscalev
666000004 1
666000003 2 0
0 0 0 0 0
# fct_IDv Fscalev
666000003 1
# Cmerg Tswitch Iswitch Pswitch
1e-04 20.0 0 0.0
# CFL DT_min
0.0 0.0
The /MONVOL/FVMBAG2 card is available as of 2021.1. It is an exact replication of the /MONVOL/FVMBAG1 card. Obsolete and non-used input is removed from /MONVOL/FVMBAG2. This makes it simple and easy to use. Some differences in the results between the /MONVOL/FVMBAG1 and the /MONVOL/FVMBAG1 card may come when injection velocity in /MONVOL//FVMBAG1 is set different from 300m/s. This value is hard coded in the /MONVOL/FVMBAG2 card.
The closed airbag external surface should be defined using /SURF/PART and reference a set of shell components with normals directed outwards.
The scaling parameters, Ascale_T, Ascale_P, Ascale_S, Ascale_A, and Ascale_D are not used.
Atmospheric values are defined for initial air material, initial temperature, and initial pressure.
The parameter, Ittf should be set to 3. In this case, vents are activated at TTF of the first injector given in the sensor referenced in /MONVOL/FVMBAG1 and all time dependent parameters and curves controlling vent openings and porosities will be shifted by the sense activation time of the first injector
The number of injectors is specified by the Njet flag. Elements used as an injection surface should be place into separate PART component, which belongs either to the external or internal airbag surface. Different injectors cannot use same elements for injector surfaces.
Time to fire (TTF) to start gas injection should be defined in /SENSOR. Global parameter definition /PARAMETER can be used to parametrize input of the TTF and other airbag parameters.
The function for injection velocity should be set at a constant value of approximately the velocity of sound of injected gas. This function does not have significant impact to simulation results.
Option Iequil=1 should be used. The option provides a simplified FVM cycling before TTF.
Internal surfaces (internal walls, baffles, and so on) shall be defined as a collection of components and referenced in the surf_IDin field.
The Initial Finite Volume mesh is created automatically when the option /MONVOL/FVMBAG1 Kmesh=14 is used and no manually created initial tetra Finite Volume mesh is defined as described in the next section. Next, the airbag is checked to make sure no intersections exist in the airbag external and internal surfaces. If no intersections exist, the Finite Volume mesh is created. If the Finite Volume mesh cannot be created due to intersections in the airbag components, an error message is written with the possible node/element numbers and positions that are causing the problem with creation of Finite Volume mesh. When this happens, HyperMesh can be used to inspect and correct the issues with the airbag mesh. Use the check 2Dmesh option in the tetramesh panel, with default setting to see if the external and internal airbag components are acceptable for tetra mesh generation. Tetra mesh created by Radioss is output as Radioss include file MONVOL.
The initial Finite Volume mesh /TETRA4 elements should be place into a separate /PART and assigned the material /MAT/VOID and property /PROP/VOID. The mesh must completely fill the airbag volume.
/PART/8
TETRA4
8 8 0
/MAT/VOID/8
tetra
/PROP/VOID/8
tetra
INITIAL VOLUME OF MONITORED VOLUME. . .= 299199.9998912
VOLUME NUMBER 1
NUMBER OF SURFACE POLYGONS. . . . . . .= 1200
NUMBER OF SURFACE TRIANGLES . . . . . .= 1200
NUMBER OF COMMUNICATION POLYGONS. . . .= 2536
NUMBER OF COMMUNICATION TRIANGLES . . .= 2536
NUMBER OF FINITE VOLUMES. . . . . . . .= 1568
MIN FINITE VOLUME VOLUME. . . . . . . .= 66.66666700000 (FINITE VOLUME ID 292)
INITIAL MERGING VOLUME. . . . . . . . .= 19.08163264612
SUM VOLUME OF FINITE VOLUMES. . . . . .= 299199.9998912
SUM AREA SURFACE TRIANGLES. . . . . . .= 230031.1439046
SUM MASS OF FINITE VOLUMES. . . . . . .= 3.9428379122204E-04
WARNING ID : 631 ** WARNING IN FVMBAG DEFINITION DESCRIPTION : -- MONITORED VOLUME ID : 1 -- MONITORED VOLUME TITLE : SAB IN LOCAL FRAME DIRECTION 1 GIVEN LENGTH 0.000000000000 IS SMALLER THAN BOUNDING LENGTH 301.4996942325 IT IS RESET TO 304.5146911748 WARNING ID : 631 ** WARNING IN FVMBAG DEFINITION DESCRIPTION : -- MONITORED VOLUME ID : 1 -- MONITORED VOLUME TITLE : SAB IN LOCAL FRAME DIRECTION 2 GIVEN LENGTH 0.000000000000 IS SMALLER THAN BOUNDING LENGTH 100.0000000000 IT IS RESET TO 101.0000000000 WARNING ID : 631 ** WARNING IN FVMBAG DEFINITION DESCRIPTION : -- MONITORED VOLUME ID : 1 -- MONITORED VOLUME TITLE : SAB IN LOCAL FRAME DIRECTION 3 GIVEN LENGTH 0.000000000000 IS SMALLER THAN BOUNDING LENGTH 1.535460483274 IT IS RESET TO 1.550815088107
The quality of tetra mesh is not important because the finite volumes based on the tetra mesh will be merged according to the strategy provided by the merging parameters. , , and can be entered in /MONVOL/FVMBAG1. However, it is recommended to deactivate the merging process during Starter initialization by setting = =1e-04 and use an advanced merging algorithm in the Engine, where the same parameters can be defined in /FVMBAG/MODIF or /DT/FVMBAG/Iflag.
From version 2019.1, merging parameters and time step parameters can be input directly in the /MONVOL/FVMBAG1 and /MONOL/FVMBAG2 cards.
The number of tetra elements depends on the complexity and the type of airbag. For example, a side airbag can be about 30,000 – 50,000 tetras, and a curtain airbag 250,000 – 500,000 tetras.
The automatic volume meshing option /MONVOL/FVMBAG1 Kmesh=1, should not be used. It is recommended to either use Kmesh=14 (HyperMesh tetra mesher) or manually create the tetramesh in HyperMesh.
