Airbag Setup Recommendation
Airbag Materials
Recommendations for fabric material model setup using LAW19.
| LAW19 Option | Recommended Value | Recommended Option Details |
| RE | 0.001 < RE < 0.01 | If RE > 0.01 the compression stiffness is too high. |
| ZeroStress | 1 | Airbag pre-strain is applied correctly. |
| sens_ID | Use the same sensor as used in /MONVOL card | Fabric pre-strain through reference geometry must be activated at time to fire. |
Recommendations for fabric material model setup using LAW58.
| LAW58 Option | Recommended Value | Recommended Option Details |
| B1 and B2 | > 0 | B1 and B2 values should be positive. |
| Flex | 0.01 | The default value is adequate. |
| G0 < GT | -- | Shear parameters should be consistent. |
| Enter value in degrees | Shear locking angle shall be entered in degrees. | |
| sens_ID | Same sensor that is used in /MONVOL card | Fabric pre-strain through reference geometry must be activated at time to fire. |
Airbag Properties
Recommendation in fabric properties /PROP/TYPE9 (SH_ORTH) and
/PROP/TYPE16 (SH_FABR).
| Property Option | Recommended Value (per material) | Recommended Option Details | |
| LAW19 1 | LAW58 2 | ||
| Ish3n for trias | 2 | 2 | This is the default tria formulation. |
| Ismstr for trias | 1 | 4 | Best practice recommendation for 3 node trias |
| Ishell for 4-node shells | 12 | 12 | This formulation avoids hourglassing. |
| Ismstr for 4-noded shells | 11 | 11 | Must be used with Ishell =12, 4 node shells. |
| N | 1 | 1 | Enable membrane formulation |
| Thick | > 0 | > 0 | Thickness must be defined |
| Iplas | 0 | 0 | Not relevant for fabric |
| Ithick | 0 | 0 | Not relevant for fabric |
| Vx, Vy, Vz | Non-zero vector | Non-zero vector | This input defines a vector which determines first orthotropy direction. If not defined the Global X- axis is used. |
| Idril | 0 | 0 | Not relevant for fabric |
Airbag Self-Contact
If all
intersections can be removed from the airbag, then surface to surface and edge
contact and be defined using /INTER/TYPE19. In some advanced
cases, it is better to define the two separate contacts,
/INTER/TYPE7 for node to surface and
/INTER/TYPE11 for edge contact.
| Interface Options | Recommended Value for contacts TYPE7, TYPE11 and TYPE19 | Comments |
| Intersections | No intersections | No intersections are allowed. |
| Penetrations | Penetrations < 95% gap | All penetrations > 95% gap need to be removed. |
| Istf | 4 | Interface stiffness is the minimum of the main and secondary stiffness. |
| Stmin (kN/mm) | 1 | Avoids contact that is too soft. |
| Idel | 0 | Not relevant for airbag self-contact. |
| Igap | 0 | Constant gap is used as defined by Gapmin. |
| Gapmin | 1.0 mm | For TYPE11, use Gapmin =0.9mm |
| Inacti | 6 | Automatically remove initial penetrations by reducing the contact gap. |
| Fric | 0 | No friction used in airbag self-contact. |
| Ibag | 1 | Block vent holes and porous fabrics during contact. |
If it is not possible to remove intersections, then
/INTER/TYPE23 can be used with these recommended
values.
| Interface Options | Recommended Value for TYPE23 | Comments |
| Gapmin | Thickness of fabric material | This value determines both contact gap and contact depth, too high values will mean that intersected nodes will not be released due to too high contact depth. |
1 Fabric material LAW19 is only compatible with /PROP/TYPE9
(SH_ORTH).
2 Fabric
material LAW58 is only compatible with /PROP/TYPE16
(SH_FABR).
