/EBCS/VALVIN
Block Format Keyword Describes the elementary boundary condition to describe inlet valve (imposed density and pressure).
| /EBCS/VALVIN/ebcs_ID/unit_ID | |||||||||
| ebcs_title | |||||||||
| surf_ID | |||||||||
| C | |||||||||
| fct_IDpr | Fscalepr | ||||||||
| fct_IDrho | Fscalerho | ||||||||
| fct_IDen | Fscaleen | ||||||||
| lc | r1 | r2 | |||||||
Definition
| ebcs_ID | Elementary boundary
condition identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| ebcs_title | Elementary boundary
condition title. (Character, maximum 100 characters) |
| surf_ID | Surface
identifier. (Integer) |
| C | Speed of sound. Default = 0 (Real) |
| fct_IDpr | Function
identifier for pressure.
(Integer) |
| Fscalepr | Pressure scale
factor. Default = 0 (Real) |
| fct_IDrho | Function
identifier for density.
(Integer) |
| Fscalerho | Density scale
| fct_IDen | Function
identifier for energy.
(Integer) |
| Fscaleen | Energy scale
| Characteristic
length. Default = 0 (Real) |
| r1 | Linear resistance. 5 Default = 0 (Real) |
| r2 | Quadratic resistance.
- Input is general, no prior assumptions are enforced! Verify that the elementary boundaries are consistent with general assumptions of ALE (equation closure).
- Compatible with /MAT/LAW6 only.
- Density, pressure, and energy are imposed according to a scale factor and a time function. If the function number is 0, the imposed density, pressure and energy are used.
- This keyword is less than four
or equal to six (non-reflective frontiers (NRF)) using:
Pressure in the far field is imposed with a function of time. The transient pressure is derived from , the local velocity field V and the normal of the outlet facet.
Where, is the characteristic length, to compute cutoff frequency as:
- A resistance pressure is
computed and added to the current pressure.
It aims at modeling the friction loss due to the valves.
