/EBCS/INIP
Block Format Keyword Describes the elementary boundary condition of initial pressure.
/EBCS/INIP/ebcs_ID/unit_ID
ebcs_title
surf_ID
Rho C l c
Definition
ebcs_ID Elementary boundary condition identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
ebcs_title Elementary boundary condition title.
surf_ID Surface identifier.
(Integer)
Rho Initial density.
Default = 0 (Real)
[ kg m 3 ]
C Speed of sound.
Default = 0 (Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
l c Characteristic length.
Default = 0 (Real)
[ m ]
  1. Input is general, no prior assumptions are enforced! Verify that the elementary boundaries are consistent with general assumptions of ALE (equation closure).
  2. Compatible with /MAT/LAW6 only.
  3. Density, pressure, and energy are imposed according to a scale factor and a time function. If the function number is 0, the imposed density, pressure and energy are used.
  4. This keyword is less than four or equal to six (non-reflective frontiers (NRF)) using:
    ∂ P ∂ t = ρ c ∂ V n ∂ t + c ( P ∞ − P ) l c
    Pressure in the far field P ∞ is imposed with a function of time. The transient pressure is derived from P ∞ , the local velocity field V and the normal of the outlet facet.
    Where, l c is the characteristic length, to compute cutoff frequency f c as:
    f c = c 2 π . l c
  5. A resistance pressure is computed and added to the current pressure.
    P r e s = r 1 ⋅ V n + r 2 ⋅ V n ⋅ | V n |
    It aims at modeling the friction loss due to the valves.
