2026
These materials can be used to represent multi-material, fluid and explosive materials.
Block Format Keyword Up to four material laws can be defined: elasto-plastic solid, liquid, gas and detonation products. The material law is based on a diffusive interface technique to get sharper interfaces between submaterial zone (/ALE/MUSCL in Radioss Starter Input).
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword The following tables list the compatibility options for each of the material laws.
These materials can be used to represent elasto-plastic materials.
These materials can be used to represent hyper and visco-elastic materials.
These materials can be used to represent composite and fabric materials.
In Radioss these materials can be used to represent rock or concrete materials.
These materials can be used to represent honeycomb materials.
These materials can be used to represent connection materials.
These materials can be used to represent other materials.
Block Format Keyword This law describes the Jones-Wilkins-Lee EOS for detonation products of high explosives. Optional afterburning modeling is available.
Block Format Keyword Describes a fluid material. Pressure is computed using Equation of State provided by definition of /EOS option.
Block Format Keyword This material law describes detonation products using an ignition and growth model of a reactive material.
Block Format Keyword This law describes the Jones-Wilkins-Lee-Baker EOS for detonation products of high explosives.
Block Format Keyword Simulation of multi-fluid compressible flows by defining a sub-material and initial volume fraction.
Block Format Keyword This law describes the boundary conditions material in flow analysis (ALE or EULER). It is compatible for 2D and 3D analysis. It is not compatible with Multi-Material ALE laws, LAW37 (BIMAT) and /MAT/LAW51 (MULTIMAT). In case of turbulence, activate boundary turbulence modeling using /MAT/B-K-EPS and input κ - ε ˙ boundary conditions.
Block Format Keyword This law describes thermal material.
Block Format Keyword ALE multi-material law for 2D analysis.
Block Format Keyword This ALE material law describes a SESAME tabular EOS, used with a Johnson-Cook yield criterion.
Block Format Keyword Describes the hydrodynamic bi-material liquid gas material. It is not recommended to use multi-material laws with Radioss single precision engine.
Block Format Keyword This boundary material enables to impose sub-material states (density, energy, and volumetric fraction) which are also used to compute global material state. Submaterial EOS parameters must be consistent with the ones in adjacent element (from the domain).
Block Format Keyword This boundary can simulate gas inlet conditions for multi-material ALE laws (formulation: Iform = 0, 1, 10, or 11).
Block Format Keyword This boundary can simulate liquid inlet conditions for multi-material ALE laws (formulation: Iform = 0, 1, 10, or 11).
Block Format Keyword This boundary material enables you to simulate a non-reflecting outlet boundary for multi-material law /MAT/LAW51 (Iform = 0, 1, 10, or 11). This material is useful to model an infinite domain. Elements assigned this material law act like a non-reflecting elementary boundary.
Block Format Keyword ALE and CFD options used to activate ALE formulation or Eulerian formulation for a given material law.
Used by Radioss to compute the hydrodynamic pressure.
The supported failure models in Radioss.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
