MASSTOH3D
I/O Options EntryThe MASSTOH3D command can be used in the I/O Options section to request the output of the mass matrix to the .h3d file.
MASSTOH3D = option
Argument Options Description
option <YES, ALL, NO, NONE, blank>
Default = ALL
YES, ALL, blank
Mass matrix is output to .h3d file.
NO, NONE
Mass matrix is not output.
  1. Mass matrix is not output if this card is not present.
  2. This option is only for use with MotionView's MBD Flexbody utility.
