DOPTPRM, MINMETH
Bulk Data Entry This parameter specifies the method of minimum member size control.
| Parameter | Values | Description |
| MINMETH | Integer =
1,2 Default = 2 |
Specifies the method of minimum member size control. Method 2 is set as default since it achieves more discrete solutions for most examples. |
