Input
In this section the general input for any FSI run is discussed.
For detailed information regarding specific SFSI/TFSI input data, refer to the corresponding document. In OptiStruct-AcuSolve FSI, you typically only need to define the fluid-structure interface to run Fluid-Structure Interaction Analysis.
SURF ID of 10, the input data would
be:FSI,2,10In this case, all of the other parameters are set to their default values.
In order to reduce run times, it is recommended to set an upper bound on the number of exchanges/staggers, as well as setting higher values for the solution variable convergence tolerances.
FSI,2,10,,,,0.01,0.01The FSI Bulk Data Entry in OptiStruct should be referenced in the Subcase Information section by a corresponding FSI Subcase Information Entry. Currently, only one FSI Subcase Information Entry can be specified in a model (in other words, within a model containing multiple subcases, only one subcase can have the FSI Subcase Entry). See General Limitations in Run FSI for further information.
Model Location
acuSolve: No. external code nodes = 170
acuSolve: No. external code tri3s = 0
acuSolve: No. external code quad4s = 168
acuSolve: No. external code tri6s = 0
acuSolve: No. external code line2s = 0
acuSolve: Min/Max x-coord = -2.500000e-001 2.500000e-001
acuSolve: Min/Max y-coord = 0.000000e+000 2.000000e+000
acuSolve: Min/Max z-coord = -2.500000e-001 2.500000e-001
acuSolve: Total surface area = 4.500000e+000
acuSolve: Total length = 0.000000e+000
acuSolve: No. external code mbds = 0
acuSolve: No. fluid wet surfaces = 18
acuSolve: Total fluid surface area = 2.250000e+000
