Skeleton Modeling
New Features
Categorize Tool
The Categorize tool has been added. The Categorize tool is designed to streamline the development of reduced order models by automating the detection and categorization of subsections with an automotive model.
Extract Line Tool
The Extract Line tool has been added. The Extract Line tool generates a mid-line representation from the selected input, which is essential for creating reduced-order models.
Auto-Offset
Auto-Offset restores the position of members after associated sections are created.
Figure 3.
Enhancements
Section Cleanup
Section cleanup will remove overspill areas of a section to reduce the section to only what's desired. The option will remove a large amount of manual cleanup.
Figure 4.
