Meshing
New Features
- Midmesh
 - A new method for midmesh has been added to handle extrusions. The two
                            available options are:
- Casting: generate midmesh optimized for casting parts. The casting method handles midmesh on complex, freeform surfaces and variations in thickness.
 - Extrusion: perform midmesh extraction on extrusion parts. The extrusion method handles midmesh on linear and consistent cross-sectional profiles.
 - Preferences
 - The Geometry and Meshing preferences are now combined under the Topology section.
 - 1D Mesh
 - Section Manager is a new environment to create, edit, and visualize
                            sections. It uses the same sketch graphics to visualize section topology
                            and a dedicated browser for section data and computed properties. It is
                            supported for sections of source type as Shape.
Enhancements
- Geometry Organization
 - The Create as new option in the Extend tool now follows the Create in setting under the Topology section for better organization.
 - Extrude
 - Selection of lines has been enabled in the target for hex creation.
