Geometry
New Features
Imprint on Surface
Sketching now supports the Imprint on surface option for sketches drawn on a parent surface geometry.
FE Geometry for Solid Boolean
Solid Boolean now supports FE Geometry for Combine, Subtract, and Intersect operations.
Create Polyline From Node Cloud Data
Creating a polyline from node cloud data is now supported under the Line Creation tool.
Enhancements
Release Point Functionality
Release Point functionality has been added to the Quick Edit tools.
Align/Project Tool Improvements
The Align/Project tool has been improved for projecting on a plane for easy selection of the plane.
