Altair HyperStudy 2025 Release Notes
New Features
- Leverage accuracy metrics as responses
- HyperStudy Pyfit model now provides an option to include fit metrics as conventional responses. This allows monitoring accuracy and applying objectives which is useful in fit-based optimization approaches.
- Deploy PhysicsAI model as solver
- A new extension tool to auto-register trained PhysicsAI models as solvers.
Enhancements
- Perform trade-off studies following input variable formats
- Tutorial HS-1100, Setting Up Existing Data Model
- Tutorial HS-1695, Using Hooks in PhysicsAI Model
Resolved Issues
- Using labels instead of model parameters in hst_output.hstp files no longer prevents extracting values of different outputs with same labels.
- Hidden or shown tabs no longer restore to default after reopening the application.
Announcements
- Data Source tool, Hstp Reader, has been deprecated and the updater will convert it to XML reader tool. Please use deprecate flag with 8319 to restore the tool.
- “setDirectory” and “setFileHint” python functions have been removed from External Optimizer API. They have been replaced with getResourcePath(type: RESOURCE_TYPE)-> str on the setup class using the resource types RESOURCE_TYPE_WORK_DIRECTORY and RESOURCE_TYPE_FILE_HINT.
