Altair HyperForm 2025 Release Notes
Enhancements
- STA file size reduction from Radioss incremental solver run
- The STA file exported from the solver run is broken into a smaller mesh file and compressed file (str.gz) that has all the initial conditions to reduce memory footprint. Use the STA file as usual to set up multistage analysis. Keep the str.gz file from the previous stage in the run folder.
- Results initializer
- The following additional parameters can now be defined for each part:
- Draw direction
- Interface friction
Resolved Issues
- Tube bending and hydro bending can now handle tube parts with special characters in their names.
