Altair HyperMesh
New Features
- A new Initial State entity has been introduced and supports all the following keywords: /INISHE, /INISH3N/, /INIBRI, and so on.
Enhancements
- A new Model Checker check has been added for RBODY in component with Part card image instances with auto correction.
- Mass calculation has been improved in the Validate and Mass Measurement workflows when a lumped mass is applied on a free RBODY secondary node.
Known Issues
- After switching from the OptiStruct to Radioss solver profile, the RBODY node set is now correctly created on export.
- Auto correction of the Model Checker check for RBODY main node on element instances now works for two nodes RBODY type.
