Altair PhysicsAI 2025 Release Notes
Announcements
License checkout for prediction outside Altair GUI products, like HyperMesh or Inspire, will now draw 150 Altair Units.
New Features
New Architecture Introduced - Transformer Neural Simulator (TNS)
PhysicsAI now has a new AI training method - the Transformer Neural Simulator (TNS). This is in addition to the existing method, the Graph Context Neural Simulator (GCNS). Some key differences between the two:
  • Usually, TNS should predict smoother contours than GCNS.
  • TNS is less sensitive to variation in mesh sizes.
  • On a GPU, TNS is faster than GCNS while on a CPU, it is typically the opposite.
Natively Reading Simulation Entities (Thickness and Material IDs)
PhysicsAI can now extract thicknesses and material IDs if there are solver decks available along with the training files. These decks should be in the same location and have the same name as the corresponding solver file. For example, if a file called Ibeam.h3d has a file accompanying Ibeam.fem, then the thicknesses and material IDs can be parsed by selecting Extract Simulation Properties.
The list of supported solver decks include: Optistruct, Radioss, LS-DYNA, Nastran, Abaqus, and ANSYS.
Enhancements
Mesh Alignment for Translational Invariance
PhysicsAI is sensitive to meshes being translated and rotated in space. Earlier, you had to manually orient the meshes to eliminate this source of noise. Now, using the Mesh Alignment feature during model training, the meshes can be adjusted during training, testing, and prediction. The meshes are aligned such that the center of gravity is coincident at a common point. This option can only correct translational variances and not rotational variances.
Figure 3.
Enhanced Dataset Visualization and Outlier Detection
Previously, you had to utilize other tools, such as HyperStudy, to curate the data and identify outliers. Now, outliers in the dataset are identified based on the you select. A Z-distribution is fitted to the data and points that fall in the 3-sigma tails are highlighted as outliers.
Figure 4.
Similarity Score in the PhysicsAI Connection in HyperStudy
You can now access the Similarity score for a prediction made using a physicsAI model in HyperStudy. This can be a useful response to qualify results based on expected accuracy. For example, using it as a constraint to reject predictions with low Similarity scores. The Similarity score is automatically added as a response if it is available in the selected physicsAI model.
Figure 5.
Known Issues
  • Predictions made in the Radioss solver profile within HyperMesh may not function correctly when model features are used (like thickness or material). This issue can be avoided by using another solver profile, such as OptiStruct.
Resolved Issues
  • Eroded elements are now hidden during visualization. Previously, eroded elements resulted in an exploded mesh resulting in confusing visualization. Now, elements are hidden after the point of erosion.
    Figure 6.
    Figure 7.
  • Previously, errors were encountered if the training data contained parts with no results. Now, physicsAI automatically excludes such parts and the training can continue.
    Figure 8.
