Safety Report Manager
Highlights
  • Altair Safety Report Manager is capable of generating reports for Seat Impact load cases.
  • Radioss and PAM-CRASH solver support is added for all structural modules across frontal, rear, and side impact regulations.
  • The following standard modules are now included:
    • Altair Time History Plotter (ATP)
    • Contour Plot
    • Animation New
    • Measure Plot
New Features
Seat Impact Load Cases
The following seat impact load cases are now supported:
  • Whiplash load case for EURO-NCAP, CNCAP, JNCAP, and KNCAP regulations.
  • Energy Dissipation and Static Headrest test load cases for AIS 016, ART 18b, ECE R17, FMVSS 202a -5, GB 14167, and KMVSS 103 regulations.
  • The Seat Belt Anchorage Description module is now available as part of the ECE R14 regulation.
  • The Luggage Retention module is now available as part of the ECE R17 regulation.
The following new standard modules are included:
  • Seat bolt recliner moment
  • Floor bolt force
  • Belt forces
Occupant Modules
The following occupant modules are now supported:
  • Frontal impact - UN Regulation137 Rigid Barrier In-Position
  • Frontal impact - UN Regulation94 Deformable Barrier In-Position
  • Frontal impact - EuroNCAP - MPDB
Enhancements
Frontal Impact Structural Module
The following enhancements have been made to the Frontal Impact Structural module:
IIHS - SORB Intrusion Module
This module is enhanced to support 3D animation results data. The SORB Intrusion module now supports both time history data as well as 3D animation results data.
IIHS - ODB Intrusion Module
This module is enhanced to support 3D animation results data. The ODB Intrusion module now supports both time history data as well as 3D animation results data.
MPDB Intrusion Module Improvements
The following improvements were made:
  • Added the capability to create an intrusion grid pattern.
  • Allow editing of the regulation-specific limits for Standard Deviation (SD) and OLC values in the modifier plot.
  • Included the evaluation area for the bottoming-out picture.
  • Added the barrier intrusion value in the spreadsheet.
Generate Run Script
This feature is now included. This generates a Windows batch file (.bat) and Linux shell script file (.sh), which can be used to run Altair Safety Report Manager in complete batch mode (non-GUI) for both the single and overlay run modes.
Added the Best View Capability to the Plastic Strain and Displacement Contour Modules
Added the capability to control the sequencing of modules in the final PowerPoint (PPT) and HTML report.
Known Issues
The following known issues will be addressed in a future release as we continuously improve performance of the software:
  • Input validation check is not supported for the Battery Section Force and BOM modules.
  • The Load Path, Run Statistics, and Weld Failure modules are not supported for the Radioss and PAM-CRASH solvers.
Resolved Issues
The issues related to the following modules have been addressed.
  • Application error with Engine Mount Failure.
  • In Run statistics, the solver version is missing due to format change in solver message file.
  • Entity type label missing in the BOM configuration file.
  • Error in the Vehicle Kinematics vertical and the Structure Plastic Strain.
