Connectors
New Features
- Auto Area Tools
- This feature can be used to select Parts/Components and create Area
Connectors within the a specified Tolerance. The result will mirror the
result from the Auto Contact tool.
Figure 1. - Capture Shape Attachments
- These new attachment options allow a shape selection and dimensioning.
Any nodes within the selection on the part link is then selected. The
different shapes are sphere, box, and cylinder.
Figure 2. - Contact Connectors
- This feature can be used to create contacts from the connector. This
realization creates set-based contacts between areas identified by the
connector projection. This is supported from both line and area
connectors.
Figure 3.
Enhancements
- Assembly Migration
- Assembly links are now migrated to group links containing all of the components in the assembly.
- Connector Graphics
- The connector graphics for area connectors have been overhauled.
- Miscellaneous
- New attributes have been added to connectors to access more projection information for customization.
Resolved Issues
- Hole type realizations are no longer failing with an open hole.
- Partially skinned solids are now treated as a single link during realization.
- The vector attribute on a connector now reacts appropriately to the Move tool.
- Solid fasteners now create a system when the option is selected.
