2026
Explore the user interface.
View new features for HyperStudy 2026.
A multi-disciplinary design exploration, study and optimization software.
The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
The Study Explorer displays a hierarchical view of your study setup and approaches, and can be used to guide you through the study setup process.
The Study Directory displays all of the files in the current study folder, that is the study in use in the Study Explorer.
The work area is where you define study models, input variables, output responses, and approach details, and post process results.
The Message Log window, located at the bottom of HyperStudy, logs warnings and errors encountered while you are conducting your investigation.
The status bar, located at the bottom of HyperStudy, displays supplemental information about your study.
Configure the view of HyperStudy.
How you use HyperStudy depends on your model type, your simulation software and your design objectives among other factors. You can use HyperStudy as a standalone software or you can start it from another product.
Once you have finished setting up your study, you will need to select one or more study approaches to find the answers to your study questions. The best combination of approaches and the best method to use for each approach depends on your application and objectives.
Discover HyperStudy functionality with interactive tutorials.
A study is a self-contained project in which models, variables, output responses, and approaches are defined.
Each approach in HyperStudy serves a different purpose in the design study.
Customize HyperStudy by registering solver scripts, functions, and optimizers, and defining user preferences files.
Keyboard shortcuts used to access HyperStudy features.
This section provides quick responses to typical and frequently asked questions regarding HyperStudy.
