What's New
View new features for HyperStudy 2026.
Altair HyperStudy 2026 Release Notes
New Features
- Inspire Model
- Seamless integration into advanced geometry modeling and a fast analysis environment.
- Spice Model
- A new model type to integrate electronic circuit board simulations. Any solver type with netlist file (*.net, *.cir) support, such as LTspice, Ngspice, and HyperSpice, can be executed.
- Have Your Own Way of Visualizing Data via Plotly
- Python-based custom plotting can now be integrated as an option in the post-processing area.
- Onboarding Custom Distribution Schemes
- Reliability-based studies now support user-defined distribution types.
- Perform Reliability Assessment Based on Optimum Values
- A shortcut button has been added to the post-processing step of Optimization, DOE, Fit, and Sampling Fit approaches to effortlessly create a Stochastic Approach, which bases the expected input values on the selected run.
Enhancements
- The definition of distributions has been restructured to make it more user-friendly, and the Distribution Role has been completely removed.
- A progress bar has been introduced to track the progress during the apply-specification stage.
- External algorithms are now registered under the same option, Register External Algorithm.
- Via the Python API, each task can be performed per model (write and execute) or response (extract) independently.
Resolved Issues
- Dark mode GUI issues.
- FMI model did not support string variables.
- Some tutorials were missing in the Tutorials tab.
- Unable to display files in the PhysicsAI ribbon.
Announcements
- The Hstp Data Source tool will be removed in version 2026.1.
- The Python API module, alt.hst.postprocessing.hstdataset, has been deprecated and replaced with alt.hst.api.dataset.
