Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
FEMT 2023: X Factor
Introduction
The X Factor allows the user to adjust the iron losses to his measurements and recompute the efficiency of his motor with a better accuracy. The X Factor is a floating value by which the iron losses amplitude is multiplied.
The X Factor can be accessed:
- before solving: in the Input Parameters
- after solving: in Post-process with a New Command
- Iron Losses (Rotor + Stator) in Torque-Speed Area
- Rotor Iron Losses in Torque-Speed Area
- Stator Iron Losses in Torque-Speed Area
- Total Losses in Torque-Speed Area (including Iron Losses)
So with MTPA Fast and MTPV Fast modes, the X Factor is not available.
Steps to define X Factor before solving
The X Factor parameter has been added to the list of Input Parameters.
The default value is 1.
The X Factor will be applied when a new test is run.
- Open your FEMT component generated by Flux
- Configure your inputs, including the X Factor parameter
- Run the test by clicking on
→ Solving is launched
→ After solving is complete, maps are computed and displayed
- Post-process the results
→ You can see the Iron Losses maps and Total Losses maps impacted by the defined X Factor value
→ The X Factor value used appears in the Inputs table corresponding to the test in the middle area
Steps to define X Factor after solving
The X Factor can be modified after a test has been run. It allows you to quickly obtain a new test with a new set of values, which you do not need to solve again. It is simply a matter of recomputing the values of the maps to be displayed, taking into account the new set of values for the possible parameters (including the X Factor).
- Edit a test already solved and click on Post-Process with new values
for the command
→ The Post-process with a new command dialog box opens
Enter the new X Factor value and validate
→ Maps are rebuilt
→ After rebuilding, the new maps are displayed
