Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Flux 2023: New and Updated Macros
Here the list of new and updated macros implemented in the Flux 2023 release.
LUT_4SystemAnalysis_nphases (new)
Adaptation of the LUT_4SystemAnalysis macro for any number of phase number.
There are three new macros:
- LUT_2D_4SystemAnalysis_nphases
- LUT_3D_4SystemAnalysis_nphases
- LUT_Skew_4SystemAnalysis_nphases
Plus, the outputs written in a .mat file that can be read for Flux-Activate/PSIM coupling. This macro has been created to make system analysis of your e-motors easier.
MeshingForShapeOptim (New)
This macro controls and generates meshes adapted to Free Shape Optimization problems. The macro can be executed by simply selecting the lines for optimization. The macro will disable relaxation on these lines and enable relaxation on faces with a value between 0 and 1 (defined by the user).The sharpness of the created optimization mesh is controlled with the mesh size input parameter. This has a huge impact on the optimization result. The mesh size of the lines for optimization can be also controlled.
BertottiIronLossesVsSlipAcIm & BertottiIronLossesVsSlipAcImSk (New)
Theses macros have been updated to stop using deprecated iron losses model that won’t appear in the 2023 version of Flux.
If you were scripting this macro, please modify the coefficient to obtain correct results.
CreateFluxMotorInnerMagnetWithGeometricParameter (New)
This macro creates an Excel file which is the input format for FluxMotor part Library. It will allow importing a file with FluxMotor, keeping the geometric parameters used by points definitions.
