Informations on the entities: Display PyFlux, List and entity used by
Introduction
This paragraph presents the different commands that equip the user to display information regarding the entities: Displaying the PyFlux expression, Listing and Using by.
Role of information commands
The role of each of the information commands of an entity is described below.
Command Function/Use
Display PyFlux command
This command permits the display of the Pyflux expression associated with an entity.
The user can recover it to use in a python sequence.
List
This command permits the list of the contents of an entity type to be displayed.
This command is accessible only starting from the contextual menu of an entity type.
Entity used by This command permits the user to know all the entities related to an entity
Access to entity information commands
The information commands are accessible starting from the contextual menu of each entity or entity-type.
