Describing the sources
Introduction
The only one possible type of source is characterized by:
- an imposed value of the electric potential (V0)
The Flux describing of this type of source is detailed in the following blocks.
Imposed electric potential
It is possible to impose an electric potential (V0) on a region by using the regions known as non-material of the type: imposed electric potential.
The electric potential imposed on a face region (3D) or on a line region (2D/3D) can be constant or time variable (step, sinus, trapezoidal…)
It is defined by:
- its expression (in Volts)
This value can be uniform or space dependent.
