Describing material media
Introduction
The material media are modeled by material regions :
  • mainly volume regions in 3D problems; surface regions and line regions are also possible in 3D
  • mainly surface regions in 2D problems; line regions and point regions are also possible in 2D
For additional information about the role of regions, see chapter Physics: principles.
Material regions: overview
Volume, surface or line material regions allow the modeling of the material media (with materials). The physical properties of the medium are those of the corresponding material region.
A region… enables the modeling…
Magneto Static/ Transient Magnetic air or vacuum
of the air or of the vacuum
(permeability μ r =1)
(hard material or
soft material)
magnetic non conducting
of a medium:
magnetic (permeability μ r )
non-conducting
coil conductor1
of a medium:
conducting with source1
non-magnetic (permeability μ r =1)
→ this medium represents a coil:
  • constituted of a number of turns
  • passed through by a current J s
laminated magnetic non conducting2
of a laminated medium:
magnetic (permeability μr)
non conducting
this medium represents a stacked magnetic sheets2 :
  • planes (2D plan / 3D) ou cylindriques (3D)
  • simplifié via une technique d'homogénéisation
(soft material)
A region … enables the modeling …
Specific Transient Magnetic solid conductor
of a medium:
conducting (resistivity ρ)
(can be: passive/active)
1 See Describing the source
Thin regions
Thin regions enable the modeling of regions of slight thickness.
  • The following region types are available for a 2D application:
    • Air-gap (= Air or vacuum ) region
    • Coil conductor region
    • Solid conductor region (passive or active)
  • The following region types are available for a 3D application:
    • Magnetic region
Filiform regions
Filiform regions enable the modeling of small cross-section regions.
  • The following region type is available for a 2D application:
  • The following region type is available for a 3D application:
    • Magnetic region
