Transient Magnetic application: principles
Introduction
This chapter deals with magnetic applications (Transient Magnetic) and answers the following three questions:
- What is possible to model with Flux? (Flux capabilities, typical problem, mathematical models)
- How is a Flux problem described? (description of material media, sources, boundary conditions…)
- How are results analyzed with Flux? (processed quantities available, explanation of results…)
Reading advice
Before approaching the Transient magnetic application: principles chapter, you should read the Magneto Static application: principles chapter.
