Power balance (Transient Magnetic application)
Introduction
In Transient Magnetic application, the resolution is carried out for each time step. The power balance is carried out for a time interval defined by the user.
Sub-systems definition: reminder
A system comprises one or more sub-systems as the one presented in the figure below.
Computation / results
For each of the sub-systems, as well as for the time interval defined by the user (Δt = t2 - t1), the following quantities are computed:
  • the stored energies (instantaneous values, for t = t1 and for t = t2)
  • the dissipated powers (mean values over the time interval Δt)
Attention: In the presence of symmetries and/or periodicities, the results correspond to the whole device, contrary to what is usually carried out in Flux.
Remember: The results usually correspond to the part of the device represented in the finite elements domain, with the exception of the magnetic flux in the coils, the forces/torques applied on mobile mechanical sets.
Stored energies
For the stored energies, a summary of the computed quantities is presented in the table below.
Sub-system
Stored energy (at a moment t) (in J)
Internal
Magnetic energy stored in the computation domain: , with
Internal mechanical energy:
Electrical
Energy stored in the coils:
Energy stored in the capacitors:
Mechanical
External mechanical energy
Attention: In reference to the energy stored in the coils, the initial current is not taken into consideration in Flux at the present moment.
Dissipated powers
For the dissipated powers, a summary of the calculated quantities is presented in the table below.
Sub-system
Losses (instantaneous values) (in W)
Losses (mean values) (in W)
Internal
Losses by Joule effect in solid conductors
Losses by Joule effect in stranded conductors
Internal mechanical losses:
(translating motion)
(rotating motion)
Electrical Losses by Joule effect (resistive components):
Mechanical
External mechanical losses:
(rotating motion)
