Magnetic materials with nonlinear characteristic
Reminder of the problem
In a Steady state AC Magnetic application, the unknown variables (potentials) and the physical quantities which derive from them (magnetic field strength and magnetic flux density) are sinusoidally time-varying.
Thus, the representation by complex images is used, and the solution is obtained with only one solving.
Hence, it is not possible to take into account magnetic materials with nonlinear characteristics. In fact, in the presence of nonlinear materials, the magnetic field strength H and the magnetic flux density B cannot vary simultaneously sinusoidally (see § Equivalent models for Steady state AC Magnetic applications).
Energetic method (equivalence)
To take into account material with nonlinear characteristics of magnetization, a method based on energetic equivalence allows defining a relation B(H) called “equivalent”, which considers that the equivalent H and B quantities are sinusoidally time-varying.
This method as well as the models proposed in Flux are presented in chapter Materials: principles (see § Equivalent models for Steady State AC Magnetic applications).
Warning
This method provides good results for global quantities. The computation of local quantities is available, but the results can be meaningless.
