SimLab Tutorial: MT3D Axial Flux Machine
This study case is devoted to the modeling and analysis of an axial flux machine with one internal rotor and two external stators. The motor geometry and meshing description are defined by using the AFM modeling tool, as shown below.
Basic EM analysis
The coil regions are shown in the figure below, and it is coupled with a circuit defined with the [Circuit Designer]:
Three basic scenarios (BackEMF, Constant Speed, and Starting) are created for some basic electromagnetic analysis. After solving these scenarios, SimLab can provide some basic post-processing for the eMotor analysis, including the iso-value visualization and the physical quantity plotting:
Example access
All files corresponding to this example are accessible in the following link: Tutorial package.
Example: After installing the SimLab 2025 release, you can find the latest Tuto_2024.zip package. This means that the tutorial has not been updated since 2024 release, that the tutorial does not need to be updated, and that the tutorial still works in 2024.1 release and 2025 release.
Step to follow:
- to follow the example step by step, the corresponding files are in
"Example_name_StepByStep" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to play manually the tutorial by following the step by step document
- Output folder: empty (contains the obtained results after to play the tutorial)
- Tutorial folder: contains the document describing the example step by step
- to play the tutorial by scripts, the corresponding files are in
"Example_name_PlayScripts" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to run scripts of the tutorial
- Output folder: empty (contains the obtained results after to play scripts of the tutorial)
- ScriptsTutorial folder: contains script files to be able to play each analysis
