Reciprocal Configuration
The antenna reciprocity theorem relates the antenna load current for given plane wave excitation to the radiation pattern when the antenna is excited. The antenna is assumed to be made of linear and reciprocal components.
With the CADFEKO reciprocal excitation configuration, the antenna load response under plane wave excitation can be computed as a post-processing step in POSTFEKO using the reciprocal configuration application macro.
