An antenna array is used to show the workflow of the application macro and calculate the interference matrix for the multiport
scenario.
In three_dipole_example.cfx, three dipole antennas are created and
positioned a distance from each other. Electric symmetry is used to reduce runtime but
is not required.Figure 1. Example of model setup for the three dipole scenario.
Tip: Find the examples in the <FEKO_SHARED_HOME>
directory:
In the S-parameter solution request, all the ports are added, and the
characteristic impedance for each port is set to 50 ohms.Figure 2. The Request S-parameters
dialog.
Restriction: All ports of interest need to be added to the S-parameter request, and all ports in the request must be set active.
The application macro calculates the complete interference
matrix for all ports in the request.
