Topics Discussed in this Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Launch CADFEKO.
- Define variables to create a parametric model.
- Add a custom workplane.
- Create a rectangle.
- Create a line.
- Create a cuboid by sweeping the rectangle along the line.
- Create a flare.
- Union the flare and cuboid to ensure the parts are electrically connected.
- Remove a redundant face in the flare to create a horn.
- Add a feed pin to the line.
- Use automatic selection in the 3D view.
- Create an ellipse and subtract the shape from the cuboid face to create a hole.
