Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Open the model touchstoneFedPatch.cfx.
- Save the model as completePatch.cfx.
- Delete the voltage source.
- Delete the general network connections in the schematic view.
- Delete the general network.
- Delete all the ports.
Import the model feedNetwork.cfx.
On the Import CADFEKO model window select the
following check boxes:
- Geometry
- Meshing rules
- Merge identical variables
- Merge identical media
Delete MicrostripPort2 and
MicrostripPort3.
Note: The output ports of the feed network are removed but the input ports are retained.
- Union the feed network and patch.
- Add a voltage source to MicrostripPort1 (1 V, 0°, 50 Ω).
Add a 120 Ω load to
MicrostripPort4.
Note: No output requests are necessary. The input impedance of the voltage source is computed automatically.
