Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a
session and export a report that highlights the antenna properties of the model.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Generate a model with the optimum values in Feko and
solve.
The optimisation relied on five samples within the frequency range of interest,
namely 3.96 - 4.00 GHz. To get a better sense of the frequency response for the optimum
model, it is run in Feko.
Make a copy of the original CADFEKO
model.
Update the following variables.
S1 = 0.45
S2 = 1.9254786
S3 = 2.20
Include the S-parameter configuration labelled
SParamBand that is defined over the frequency
range.
Mesh the model and run the Solver.
The results show a reflection coefficient of less than -10 dB over the design
frequency range.
Figure 1. S-parameters for the bandpass filter between 3.9 – 4.1 GHz.
