For the first solver run, the full calculation needs to be
performed. The static domain solution is stored to file and then re-used in subsequent
solver iterations. By storing the solution to the static domain (for this example the
waveguide), the Solver only
needs to calculate the effect of the feed pin location in subsequent
iterations.
View the resource requirements for each iteration.
Table 1. Comparison of resource requirements for each iteration.
Iteration
Memory (MBytes)
Runtime (seconds)
1
153
27
2
153
2
3
153
2
4
153
2
5
153
2
6
153
2
7
153
2
8
153
2
9
153
2
10
153
2
11
153
2
12
153
2
13
153
2
14
153
2
15
153
2
Note: After the first iteration, the run time was significantly reduced. This
effect of reduced run time after the first iteration becomes more pronounced
as the size of the static domain increases relative to the dynamic
domain.
View the reflection coefficient for each feed position on a Smith chart.
The port is optimally matched when the magnitude of the reflection
coefficient is as small as possible or the input impedance is equal to
50 Ω. This condition is roughly met at
iteration 6, see Figure 1. This corresponds to a feed position given by
Figure 1. Smith chart showing the reflection coefficient for each feed
pin position.
Tip: Keep the temporary files. Then create the graph by
plotting each model's source data.
