Optimise Waveguide Pin Feed Location
Analyse the effect of the pin offset on the reflection coefficient using an optimisation grid search and the NGF solution settings.
Tip: Find the completed model in the application macro library1.
1 The
application macro library is located on the Home tab, in
the Scripting group. Click the Application
Macro icon and from the drop-down list,
select Example Guide.
