Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Define the following variables.
- freq = 12.5e9 (The operating frequency.)
- lam = c0/freq (The wavelength in free space.)
- lam_w = 0.0293 (The guide wavelength.)
- h_a = 0.51*lam (The waveguide radius.)
- h_b0 = 0.65*lam (Flare base radius.)
- h_b = lam (Flare top radius.)
- h_l = 3.05*lam (Flare length.)
- ph_centre = -2.6821e-3 (Horn phase centre.)
- R = 18*lam (Reflector radius.)
- F = 25*lam (Reflector focal length.)
- w_l = 2*lam_w (The waveguide length.)
Create the horn.
Create the parabolic reflector.
Decouple the MoM and LE-PO.
Tip: Open the Solver settings dialog, click the High frequency tab and then click Decouple PO and MoM solutions.Tip: The decouple setting will save computational resources. It is not recommended where the coupling (interaction) between the PO and MoM objects is strong.
- Set the frequency to freq.
